  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
You have a mini... (mind my ignorance)
what year etc.
Special interest rego - what tha!
Its a 72 GT Clubman. Apparently 1 of only 1000 produced in Australia. All original and has had a complete ground up rebuild. Even one a couple of show'n'shine trophies.
If you are a financial member of a club and they can verify your car is what you say it is, and is over 30 yrs old you can qualify for this concessional rego. Its fairly restricted though, but fine for what I need.
cool got any pics?
One of the guys in the office here had a mini that he cut the top down (ie. the windows were only half their origonal size). It looked great, but really small. Had a lot of other performance stuff done to it, but can't remember atm. Said it went really quick and handled extremely well.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
