I know what you mean about trying to get the tube of toothpaste in...pretty awkward, and I did mine BEFORE the oil :P
* whispering to Warwick
in the first place, do you think we should have squeeze the toothpaste INTO the VMX bottle and THEN pump it into the gearbox?
* end whispering
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
As Glenn said I have been MIA the last couple of days.... had to get in the good books so I could go cruising and miss the g/f's going away party from work tonight.
She still ain't happy but I have been sooo good
so des na~~~
that explains your absences from Nick's restaurant eh.
hope you scored :P
so des na~~~
hope you scored :P
Yes I am sorry, I don't like being the "No Show" type person, but it was in my best interests so I can go cruising instead tonight :(
