  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
CH7 is just full of wankers who are so easily stirred up, all you do is call out "Your a wanker" and listen to the ensuing humor, just a bunch of idiots, but very funny to listen to!
yeah. I'm still grinning about your effort last wednesday. :P
Hope you had an alright Saturday night anyway. ;)
Line is in the shop today for that power steering thing and I probably won't see it again till wednesday ;)
