  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
thats the mentality in south africa, and if a person such as this youth leader saus to do it, the ppl at the rally/march or wotever will go out and do it
There's no justice' date=' like ANGRY MOB JUSTICE!
Yeah I have met heaps of people from over there, and not one had a bad sence of humor, they had to I couldnt help taking the piss outta that lovely accent!! :D
the afrikaans south africans have the most classic accent
there is actually a funny wav somewhere on my pc
let me upload it somewhere
warwick, try this place.  its really good as well.  they have dim sum everyday after 10pm
The Manor
The Glen Shopping Village
Cnr. Gaskell & Angel Sts, Eight Mile Plains
QLD 4113
Tel 3341 9506
I see they name a shopping centre after your good self.....:D
WTF is Eight Mile Plains?
There you go Glenn, second place is now yours for the takeing because I BEAT YOU to 2000, second place is all yours bud!! :D
congrats! :D
why stop now?.. there's still Chaos to overthrow... he's been sitting @ the throne for quite a while now :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
