  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
It's not difficult. To make a woman happy a man only needs to be :
1. a friend
2. a companion
3. a lover
4. a brother
5. a father
6. a master
7. a chef
8. an electrician
9. a carpenter
10. a plumber
11. a mechanic
12. a decorator
13. a stylist
14. a sexologist
15. a gynaecologist
16. a psychologist
17. a pest exterminator
18. a psychiatrist
19. a healer
20. a good listener
21. an organiser
22. a good father
23. very clean
24. sympathetic
25. athletic
26. warm
27. attentive
28. gallant
29. intelligent
30. funny
31. creative
32. tender
33. strong
34. understanding
35. tolerant
36. prudent
37. ambitious
38. capable
39. courageous
40. determined
41. true
42. dependable
43. passionate
WITHOUT FORGETTING TO:
44. give her compliments regularly
45. love shopping
46. be honest
47. be very rich
48. not stress her out
49. not look at other girls
AND AT THE SAME TIME, YOU MUST ALSO:
50. give her lots of attention, but expect little yourself 51. give her lots of time, especially time for herself 52. give her lots of space, never worrying about where she goes
IT IS VERY IMPORTANT:
53. Never to forget:
* birthdays
* anniversaries
* arrangements she makes
HOW TO MAKE A MAN HAPPY :
1. Shag him
2. Leave him in peace
This goes down as my quote of the year so far.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
