  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Why would you get rid of one of the best 6 cylinder engines in existence for one of the worlds most unreliable engines?
Something different, oh and that beautiful WAAAAAARP WAAAAARP WAAAAAAARP Sound :wassup: :headspin: :throwup:
