  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Dan: you must have a lot of money to throw around.. but hey it sounds good!!
I love the look of the 350z and think its one of the best looking cars on the road period. If only the performance was quite up with the look.
My folks back in Melbourne are having a bit of a mid-life crisis, there soon to buy a Z convertable. Bit of a jump from a Pulsar. I'm on the first plane back for a test drive me thinks.
:D Cops just busted me doing 73 in a 60 zone, great way to kick off the weekend, why is it I never get fines in the 'line, but in the GF's Accent?! ;)
just left charlies shop, charlie the machanic in the gabba that is.
there was a dude in a blus 32 witha black nbonnet there
left same time as me,
we bith turned into valture street
then i heard tyres then a saw drifing. left right, left, right, passed me, left right and little bit more left, then straight, was amazing, aint seen shit like that before.
seriously throwing the car from side to side, not just piss willy naaa naa stuff,
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
