  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well I dont have them yet MELV say's he has them, just waiting on a date he can put them on, or I could try myself, stuff it all totally up and end up taking them to him to put on, :P option 1 I think, :D I'M EXCITED!
You are prolly the only person not knowing that I am putting on BRIGHT GREEN racing stripes (al la dodge viper style) on my BLACK R33, to match the calipers :P
should look interesting! atleast if i ever see your car on the high way, i'll no its you.
if the incredible hulk gave birth to a skyline it would look somthang like urs SKA
Nahh it just looks like the hulk left big skid marks last time he used my car to wipe his ass :P
Hey you got a heap of points see if you can do that thief thing, I dont have enough yet :D
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
