  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:confused:
in the trunk, towards the rear left... where the jack is...
there's a wire pulley kinda thing.. and it goes all the way down to the 2nd cannon of the
stocko exhaust... and in the 2nd cannon there's a flap... so i'm guessing the pulley opens
the flap in the cannon... just wondering.. when it opens...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
