  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nick, about the work/handling pack... give it a miss first cos you are still on standard suspension setup.
focus on tyres first and also money for diff oil.
when gordon comes over, i can do your diff oil for you @ the same time. you saw for yourself how much washing was involved and the reason for the degreaser :rant:
stuffed tires (really not keen for defect)
2nd and 3rd still cruch going in (dads been to lazy to get a g/box rebuild)
and the Gear selector bush is stuffed (see above point, will be fix'd when a g/box rebuild is done)
You can still drive it in "normal" mode i guess. Its just a bit of effort.
Nick got stuffed tires... but he's still cruising with us :rant:
yeh noticed the whole degreaser thing, definitley worth the 2 bux u pay. Anyway yeh just trying to think where i want to go with modifying my car. No point just modifying my car willy nilly with no idea wat i want kind of character i want out of the car.
wat sort of plans do you have for you car?
in terms of power figures and handling?
yeah.. like glenn is saying, better make sure it handles nicely before you mess with it..
camgear could be a cheap upgrade.. I am ordering mine from nengun in a day or two.. $160 or so + shipping is cheap .. not sure whether it does as much on s2 though going from the general consensus. You can fit yours while i fit mine.
250rwhp is what i have roughly got and a lot of the other guys have got... its around 185rwkw.. that is generally S-AFC, full exhaust, pod or good air filter, electronic boost controller, and FMIC to get you there..
Yeh i can only use 1 cam gear anyway, the vct gear on the inlet side i can't change. i'd like to do tyres then exhaust then suspension/chassis setup.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
