  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ben: seems a little steep for a non turbo GTS
my mate got a 1994 (r33) GTS4: 10 cd stacker, all the usual skyline bits plus the 4WD and ABS off the GTR.. 6 months rego, safety certificate, and 77,000km (very genuine). This thing was almost as clean as it came out of the factory.. 13,900 he paid just on the weekend.
most mods aren't worth much in the end price.
Yeh i can only use 1 cam gear anyway, the vct gear on the inlet side i can't change. i'd like to do tyres then exhaust then suspension/chassis setup.
front and rear sway bar can do wonders to your handling.
i recommended Bilstein with Kings for your suspension. I had a quote b4 and its about 1.5k all up.
step by step Nick... that's how you get there.
just before i leave.. here is the one my mate just bought as a reference ben..
NISSAN SKYLINE GTS-4 1994, Gunmetal Grey, Coupe, 79000kms, 5sp, non turbo, 4WD, ABS, power everything, 10 stacker CD, 10/04 rego, immaculate
that was from the trading post..there was another for $12k, but that sold on friday..
Mildura was actually where i bought my car actually.. private sale..
there is an airport there.. from melb it was i think $80 trip one-way.. i flew there and drove hte R33 back to melb.. i still remember that really well even though it was a while ago now.
Yeh thats the best way i guess, then you can get used to each little thing you do to the car, example would be servicing the car. Can feel the difference with all the little things like brakes, engine and stuff like that. i'm thinking of the whiteline sway bars after my exhaust.....
things to do:
1. Tyres
2. Exhaust
3. Sway bars
that car was literally the cleanest GTS (or gts-t for that matter) i have ever seen..
even the floor mats looked not even used.. no scuffs even on the door panels.. amazing..
so there are plenty of good cars out there for around $12-13k if you look
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
