things to do:
1. Tyres
2. Exhaust
3. Sway bars
it should be:
1. tyres
2. get it properly tuned and looked @ by someone professional.
3. go to CES to get your dump pipe install (when you get it) and exhaust looked @
4. Front Sway Bar (27mm front)
5. Rear Sway Bar (22 - 24mm adjusttable)
4 & 5 at the same time if you can.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh probably right glenn, just this car is exactly what im after now just too bad its in victoria.
you like it becos it looks good with the kit :rant:
there's always plenty of good looking skylines around here in Brisbane.
what bout this
NISSAN SKYLINE R33 1995 SERIES 2 GTST 5 Speed Manual, Electric Windows, Airconditioned, Power Steering, Central Locking, Full Body Kit, 3inch Exhaust, Turbo Timer, Blowoff Valve, Boost Control, Boost Gauge, Sports Gear Knob and Steering Wheel, 109,000 klms, Registered, Fully Serviced, GOOD CONDITION -$16500 Highland Park (0421) 353 112.
what bout this
yeah.. can check that out... but price is low though....might wanna take a good careful look @ it.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
