  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Wassup warwick, and luke what is the point in being invisible if you are going to post?
The whole point of invisibility was so that you could lurk and not be known to everyone to be lurking in the thread?
