  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
blah got paid but looks like another tight 2 weeks :rant: i cant afford shit no more :mad: i might as well stop tunin this chick i cant afford to take someone out lol
Welcome to my world, now you know why I dun want a gf atm, they just cost too much, got more important things to spend money on, like zaust, EBC, FMIC, etc etc etc, WAY more important than stoopid gf, they're only good for one thing :rant: :rant: jk no offence intended to all our lovely women Members who might be reading this :cheers:
isn't it funny how you call one place to get a quote on something....make a booking, then call another place....get a better quote (2/3 the first one)....call the first place back to cancel the booking, and suddenly they can "match" the other persons quote......
WHY DIDN'T YOU GIVE ME YOUR BEST PRICE IN THE FIRST PLACE DICKHEAD!!!!:rant:
not very good business practice really..."we'll see how much we can sting this guy for first"
the automotive industry and its sattelite industries really piss me off
just click on the menu up the top > select thieve > enter the username of the person you want to thieve from and the number of points you wanna try for > continue
be warned though....if you fail, you lose the number of points you were trying to thieve to the person you were trying to thieve them from as well as 50 credibility points
bugger....it also seems that once you have purchased something eg. a coloured username (which I think was about 800 points), if you wanna change that and purchase a different colour, it is a shitload more expensive the second time around......so choose wisely
lol@smooth & squizz
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
