  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
HAPPY BIRTHDAY EUGENE!!!!!!!!!!!!!! 18ths are cool, i had 2 chick friends walkin around in my unit drunk in there underwear asking me if this underwear would match this skirt and shit :D i was loven it :P than my mates had to come and ruin the fun :D the girls wouldnt do it with 6 guys there
