  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I can however, teach you how to drive an automatic with a can in one hand, a smoke in the other, talk on the phone and give the person behind you the finger all at the same time! icon10.gif
They sound like some pretty solid credentials....we may be able to work out some sort of arrangement......maybe weekend visits.....do you get weekend leave from 'the big house'? :D
what brings u to visit queensland anyhow today?
its a bit cloudy today, not the best day to come say hello
well its bloody awful in melbourne, rainy, overcast, cold, so i thought i'd take a trip to QLD for the arvo. :D
Well its cloudy.. but still mid 20's.. i don't regret moving one bit :D
Glenn: As per last night, won't have car back. Will probably come along to lend a hand. Will bring my tools and stuff anyhow. Might do something to the r31, dunno.
