  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
just thinking, say if were on a mountain run that was organise by us (meaning SAU) and someone gets hurt can we or SAU (PRANK- Christian) be held responsible??
once you are up there.. its everyman for himself/herself johnny...
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
