  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
interesting fact
the rb25 afm standard has 2 layers of mesh on it, one on the inlet side and one on the outlet side
the q45 afm only has mesh on the inlet side (remember mine is brand new, yay for a good deal)
so obviously the second mesh isnt doing much, and can be done away with
interesting fact
OK getting technical now but could that have something to do with air reversion through the rb25 afm due to forced induction?
Or should I just go have a nap?
well someone once told me it was there to smooth out the flow of the air being sucked into the engine, but the way i can see it was only one screen of mesh was needed to do that, the second one served no real purpose
and there shouldnt be air coming back outta your turbo if your blow off valve is in working order
well i did notice it was more powerful but as i said at the same time i did my afm mesh i put a pod filter on too, so yer,
i cant see it making the car slower, and my turbines fins are in perfect condition so it obviously didnt cause any damage to the turbo so i guess its worth doing
mabey you should try it and see if it does infact make a difference or not
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
