  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Uhm.. Warwick, I'd like to.. But I might wait till i start my new job, then I can leave earlier..  Leaving work at 5 and getting to willowbank at 7 is just crap.
I'll come and pick your car up and drive it for you if you like :) :)
