  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
u can do it at my house one arvo, will need a good arvo to do it
sounds good...what are you doing on Sunday?
And another question....in you FMIC install pics, you don't have a fan on the front of the radiator....was there one there that you took off, or no fan at all?
had no fan there, :confused:
sunday maybe, will let you know tomorrow,
my moms bday on monday so will see if there nay supid bbq's i gotta go to
but should be free
Ok...no worries...if you're busy...some other time
In one of the pics it looks like there was a fan there at some stage, coz part of the radiator has a circular area that is cleaner than the rest
Will have a look at some other 'lines tonight and see who else does and doesn't have one
