  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey guys just wondering anyone here living out near ferny grove way?
See heaps of lines can't wait till I'm one of the gang lol Still got my first car N/A blue over silver vl commo "DVL88" so hopefully getting a s2 gts-t by sep. After driving a r33 I've now become hooked and am currently suffering from boost withdrawl lol
Well recon this site is one of the best and you guys are a great buch of ppl just cause you aren't a bunch of wanks like some of the other clubs I've driven with and they can't drive for shit. :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
