  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah I just spoke to the sysadmin and asked if we were short on room on the homepage server and he goes "yeah....prolly"
I will sort out IIS at home tonight
He does not sound geeky enough for the job, at any one time i could tell you (withing 100MB) how much space is on all our servers and in what type of raid array they are in so as to maximise out the potential free space available to any of them at any one time, gotta love big network space storage solutions :)
i did ask him if we could make some more space available, to which he said "yeah...prolly" ( I see a pattern of apathy developing)...but I don't think it's gonna be high on his list of priorities.
We can still leave the files you have already uploaded there and just upload the rest to my box at home...means ppl will have to d/l from 2 locations, but saves having to upload 800Mb again....
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
