  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
left work this arvo and was driving up the street and the engine started to die, then come back to life, die, then come back etc...had to be something to do with the piping I thought, so stopped and checked all the connections to find that I had forgotten a hose clamp on one of the joins.
Managed to limp it home and attached said clamp and proceeded to take it for a fang. Boost seemed to be building pretty slowly and I thought...I know you get a bit more lag with a front mount but this is a bit much. Anyway...gave it a real bootfull and it started coughing and spluttering and died when I came to a stop. Had a look at the piping again and found the SECOND clamp I had forgotten altogether.
Luckily I had taken a tool kit with some clamps in it and was able to fix it on the side of the road, so is now all good.
Gave it another bootfull on the way home and there is a definite improvement.
Only problem I have now is when I get to about 5000rpm it start to pop and miss, but it was doing that after I fitted the dump pipe the other week, so I think I need to change the plugs or at leas re-gap them and then have the SAFC retuned.
only a very small amount...boost prolly comes on about 3 - 400 revs later or so
ahh... just curious as to whether it was noticeable, as i've never driven mine without an intercooler as it came with one. in fact i've never driven a totally stock skyline now i think about it.. hmm..
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
