  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
left work this arvo and was driving up the street and the engine started to die, then come back to life, die, then come back etc...had to be something to do with the piping I thought, so stopped and checked all the connections to find that I had forgotten a hose clamp on one of the joins.
Managed to limp it home and attached said clamp and proceeded to take it for a fang. Boost seemed to be building pretty slowly and I thought...I know you get a bit more lag with a front mount but this is a bit much. Anyway...gave it a real bootfull and it started coughing and spluttering and died when I came to a stop. Had a look at the piping again and found the SECOND clamp I had forgotten altogether.
Luckily I had taken a tool kit with some clamps in it and was able to fix it on the side of the road, so is now all good.
Gave it another bootfull on the way home and there is a definite improvement.
Only problem I have now is when I get to about 5000rpm it start to pop and miss, but it was doing that after I fitted the dump pipe the other week, so I think I need to change the plugs or at leas re-gap them and then have the SAFC retuned.
only a very small amount...boost prolly comes on about 3 - 400 revs later or so
ahh... just curious as to whether it was noticeable, as i've never driven mine without an intercooler as it came with one. in fact i've never driven a totally stock skyline now i think about it.. hmm..
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
