  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. we did that back in our younger days.. pointed the nozzles around and squirted chicks as they went past.. was classic fun.
we were doing drivebuys.. the funniest thing was they had hardly any clue where it was coming from!
