  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had a dream about you last night James, where you were doing the 'asian old man eating style' in front of me, and I was trapped and couldnt get away...
jk
That was some funny stuff right there...
I can do it so much better if I'm eating that noodle snot ball soup and I have both chopsticks and a spoon.
:) nah.. not then.. but the **** hassling me today "this doesnt work the way i intended, can i get this feature added? did you get those emails i sent? ".. no i was out driving all night.. this is going to be the job from hell..
screw his $1400 this is why its hardly worth it
actually your car is faster too matt from a 100km/hr standing start..
i think the lesson is: mine need tune or else something else funny is going on with it?? hmm
Ive only got a 3'' exaust and a blitz pod... And my clutch was slipping... :)
Yours must desperately need a tune then matey...
