  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had a dream about you last night James, where you were doing the 'asian old man eating style' in front of me, and I was trapped and couldnt get away...
jk
That was some funny stuff right there...
I can do it so much better if I'm eating that noodle snot ball soup and I have both chopsticks and a spoon.
:) nah.. not then.. but the **** hassling me today "this doesnt work the way i intended, can i get this feature added? did you get those emails i sent? ".. no i was out driving all night.. this is going to be the job from hell..
screw his $1400 this is why its hardly worth it
actually your car is faster too matt from a 100km/hr standing start..
i think the lesson is: mine need tune or else something else funny is going on with it?? hmm
Ive only got a 3'' exaust and a blitz pod... And my clutch was slipping... :)
Yours must desperately need a tune then matey...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
