  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hows the ankle JL?
Ankle sux. I might come along and spectate tomorrow, take a few pics and stuff. Its been pretty hard trying to reallocate my spot, can only be expected on such short notice I guess. Can't help bad luck.
Good thread BTW James. Should set those straight that can't use common sense.
