  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey JL lookin at ur gallery man nice pics, what sorta mini is that? my old man reckons his old mini cooper S could give my 32 a run for its money hehehe he wishes, quite a contrast in cars
Its a GT clubman. Its exactly the same as a cooper S but in the square nose body. Mine is a stocker so its not that quick but there are plenty or cooper s minis out there that would give stock 32s and 33s a run. Nothing beats them for fun driving though, you can throw them around like nothing else.
ah ok JL yeah the old ma reckons he was out running cops around cornors and it top speed of 108 miles an hour was reached on numerous occasions... all fibs i say hes lookin at a few to buy but fark there xpensive espically some of the restored cooper S's
