  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how busy is gavin at the moment?
i want to take my car in about 2 weeks for the major service, but don't want to be waiting weeks for it to get finished.
For an appointment in two weeks you should have rung up 2 weeks ago :rolleyes:
wots wrong with it?
various things.. brakes don't work that great.. tyres are bald (although this is probably a fun thing)... timing belt at a possible 98,000km (or probably over), needs a proper tune.. many things. many many expensive things :rolleyes:
WA: Home of the Quiz Night!!
Its my new tourism campagin ..... i get about 30 letters a week from sporting clubs, schools, charites etc etc holding quiz nights n wanting freebie prizes. :rolleyes:
Hi to everyone
cyrice: is it like that is it? gives me more time to save money so i can throw it all away then :)
actually 2 weeks i'm gonna be in melb.. will spend hundreds there.. actually i'll be driving the r33 maybe sometime in early july i guess :rolleyes:
Yeah sucks to be poor, I am still trying to find someplace to sell my kidney to buy James zaust :) no luck, might have something left over when I pay for insurance as i am saving for what I paid last year, but hopefully it'll drop, no cliams, and I'll have enough with that + some other savings, to by the zaust, but that is in OCT! :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
