  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how busy is gavin at the moment?
i want to take my car in about 2 weeks for the major service, but don't want to be waiting weeks for it to get finished.
For an appointment in two weeks you should have rung up 2 weeks ago :rolleyes:
wots wrong with it?
various things.. brakes don't work that great.. tyres are bald (although this is probably a fun thing)... timing belt at a possible 98,000km (or probably over), needs a proper tune.. many things. many many expensive things :rolleyes:
WA: Home of the Quiz Night!!
Its my new tourism campagin ..... i get about 30 letters a week from sporting clubs, schools, charites etc etc holding quiz nights n wanting freebie prizes. :rolleyes:
Hi to everyone
cyrice: is it like that is it? gives me more time to save money so i can throw it all away then :)
actually 2 weeks i'm gonna be in melb.. will spend hundreds there.. actually i'll be driving the r33 maybe sometime in early july i guess :rolleyes:
Yeah sucks to be poor, I am still trying to find someplace to sell my kidney to buy James zaust :) no luck, might have something left over when I pay for insurance as i am saving for what I paid last year, but hopefully it'll drop, no cliams, and I'll have enough with that + some other savings, to by the zaust, but that is in OCT! :(
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
