  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how busy is gavin at the moment?
i want to take my car in about 2 weeks for the major service, but don't want to be waiting weeks for it to get finished.
For an appointment in two weeks you should have rung up 2 weeks ago :rolleyes:
wots wrong with it?
various things.. brakes don't work that great.. tyres are bald (although this is probably a fun thing)... timing belt at a possible 98,000km (or probably over), needs a proper tune.. many things. many many expensive things :rolleyes:
WA: Home of the Quiz Night!!
Its my new tourism campagin ..... i get about 30 letters a week from sporting clubs, schools, charites etc etc holding quiz nights n wanting freebie prizes. :rolleyes:
Hi to everyone
cyrice: is it like that is it? gives me more time to save money so i can throw it all away then :)
actually 2 weeks i'm gonna be in melb.. will spend hundreds there.. actually i'll be driving the r33 maybe sometime in early july i guess :rolleyes:
Yeah sucks to be poor, I am still trying to find someplace to sell my kidney to buy James zaust :) no luck, might have something left over when I pay for insurance as i am saving for what I paid last year, but hopefully it'll drop, no cliams, and I'll have enough with that + some other savings, to by the zaust, but that is in OCT! :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
