  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh.. guess that doesn't make sense either :thumbsup: i was saying.. when i go to sell my car soon (as that is probably what is happening).. nobody wants to pay about $23k for a nicely modified R33.. they all want to pay as little as possible, and reckon a GTS-T in good condition and pretty well cared for (for the most part) with $10k of mods should only be worth $17k.. ok its not worth $10k more, but it is worth a little more than $17k.
I tried to sell it in melbourne last year and the amount of people trying to beat me down to low figures was stupid.. considering the amount of modiifcations on it (ok, true no big turbo, etc but pretty much everything else).
pissed me off..
people like to throw money away obviously.. modifying a car from scratch costs soo much..
i bought mine with a nice selection of mods because i knew modding it from scratch would cost me 2x or 3x the price and i'd never get it back. I've done a few things, but the stuff i got on there i'd never bother changing anyhow really.
hence why i may have to consider returning it to stock to sell at a cheap price.. even though to me a stock skyline is yawn territory :thumbsup:
anyhow, i was asking what james had as stock as this may help my plan.. but he has gone..
yeah, i just bought mine and to be honest i was prepared to pay more for a un modifed one,
reason being you dont know how the modified one has been hammered prior to u buying it
yup... usually the impression is modified car = been fanged out hard...
also gives the uncertainty whether or not its been in an accident... (new front bar, etc, etc)
busy donwloading
its so ur thing.. :thumbsup:
hhmmm...
to me if a car is heavily modified if anything will go wrong it would have under stress already :thumbsup: If it brakes under stress, it would have already broke by now..but in unmodified form who knows how it will take to the extra power. On road stress testing ! :)
And you never know whether the "stock" car you bought had 50 mods in japan and exactly the same stuff was done to it over there, then returned to stock either. Plenty would have been.
i just sold (about 10 mins ago)
my stock cooler and airbox,
i still got a series 1 boot wing?
u can check the obvious tho,
always good to look at bolts and nuts in places like by the turbo and intercooler to see if they have been taken off.
..and who says stock cars aren't thrashed either?
if anything, you know the guy who has modified the car is an enthusiast, who probably has cared about the car and spent more keeping it all running nicely (extra time in the shop, getting regular tunes), more so than the guy who just bought it and just thrashed it to the shops each day.. so when it had done xx,xxx km he could trade it in for something else?
Would you buy a company or family car over here? even though of course its going to be in "stock" form?
:thumbsup:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
