  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
you haven't give me a lift so i don't have to :) :jk:
i would if i was around there
last samuari was pretty crap.. especially that part where they all got shot (like 100's of them) except good ol' Tom Cruise managaged to survive.. what a load of crok, bullets don't care who they hit
Point taken
I bought Akira Kurasawa"s "The Seven Samurai" the other week ..... now there's a Samurai movie :)
Pity it's is in black and white ..... although with the style of direction Kurasawa has, it might not have had the same mood if it was in colour
p.s. james i drove around last night with no rear seat in the r31 - **** that.. its going back in! too much noise from the ass end :) i see now why they do have a back seat, to block the annoying noises.. lol.
Its weighs 21kg anyhow, hardly a massive weight saving.
