  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn: really? thought they were spossed to be good.
they ARE good... they can power thru a corner faster than any car.... but all time 4wd are known to understeer...... and you must have the balls to increase the gas to power thru @ apex
