  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I like Beez Neez better (honey brewed beer), but the bottle-o was out of it :)
anyhow, on to cars.
I'm pumping out a mammoth 225rwhp at the moment, with only a pod filter and turbo back exhaust (no cat), and I'm thinking R34 GTT Intercooler and SAFC2 as my next mods.. any thoughts?
I reckon you're a lucky bastard...my car is still awaiting a working coil pack....must contact GT1 about it AGAIN...can't see how express post takes over a week!!!!
I'm only able to pull 0-100 in 6.6 at the moment...probably a bit to do with my lack of traction too :)
i was thinking of an R34 soon
I've had my 33 for 6 months now, and the 34's are coming down in price madly. so it may be a 34 for me soon .. although I prefer the 33 shape, and I'm seriously considering 34 front end on 33 like this (this is a gtr, and my car is not):
http://www.hkskylineclub.com/images/tmp/r3342.jpg
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
