  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I like Beez Neez better (honey brewed beer), but the bottle-o was out of it :)
anyhow, on to cars.
I'm pumping out a mammoth 225rwhp at the moment, with only a pod filter and turbo back exhaust (no cat), and I'm thinking R34 GTT Intercooler and SAFC2 as my next mods.. any thoughts?
I reckon you're a lucky bastard...my car is still awaiting a working coil pack....must contact GT1 about it AGAIN...can't see how express post takes over a week!!!!
I'm only able to pull 0-100 in 6.6 at the moment...probably a bit to do with my lack of traction too :)
i was thinking of an R34 soon
I've had my 33 for 6 months now, and the 34's are coming down in price madly. so it may be a 34 for me soon .. although I prefer the 33 shape, and I'm seriously considering 34 front end on 33 like this (this is a gtr, and my car is not):
http://www.hkskylineclub.com/images/tmp/r3342.jpg
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
