We were going to do the fmic ourselves as well to save some money, but we ran out of time with the car being booked into gav's for tuning and the cooler only arriving the day we were meant to drop it down. So I just wanted it on and stuff, I did have a choice, but I'm stubbern and wanted the cooler on asap. I've waited 2 damn years for the thing!!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
They only left the numberplate bar in because I said I was going to get the car resprayed and the panel beater would do it. But, I don't know if that is going to happen now. Plus I don't want the cooler there for poser value. It's actually doing something. Not just sticking out the front of the car screaming "HI, I'M A FMIC, PLEASE COME STEAL ME!"
I kinda like the hidden look, and it's kinda protecting it against rocks and the like. But, I know it's "KINDA" restricting flow. Not that much, but anything's a help.
hey
i was just reading your posts and wondering whats the best way to cut your bar cause i have a cooler arriving sometime this week and i want to cut the bar a little but not to much, cause i agree with what you said erin i dont want to be a posser but i do like a little show(but not to much)
i hope ive got the time to put it in too. i think im going to finish at lunch time on a friday and hit it hard friday arvo/nite. then i can get what i need on saturday and finish off on sunday. i did watch my next door neighbour put one in his 32 and it took him 4 hours from start to finish.
With a HKS cooler it should be easy like mine. Because they are actually made specifically for that type of car by a company that's reputable (is that the word?) by nissan.
I was worried it would take ages, but the only thing they had to do was cut a hole in the front drivers side to let the pipe through (that's if you aren't using the standing piping).
Wade, I'm really not sure about 32's, but in the R33's they've got a support bar behind the plastic numberplate holder which has to be cut (which is another reason mine wasn't cut out). Because I got a thicker than normal cooler (apexi coolers are thicker but not as tall) 88mm thick, they had to cut a bit of the lower lip away to fit the cooler properly. But that is the ONLY thing that was cut. Perfect fit otherwise.
Not like the hybrid kits for R33's where I've been told that the first instruction is to cut your fan blades so the pipes fit properly without hitting the pipe..
wade - do you have a gtst or gtr? my neighbour got a greddy kit i think and he didnt cut anything at all, but it was one of those kits where the pipe bends back under the cooler and fits upto the stock turbo piping. i'll be using a 70mm holesaw to drill the chassis rail.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
