  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hooray, just found this AWESOME browser, it has EVERYTHING any good hardcore surfer needs, and then some.
Funny thing found it because now we have Microsoft ISA installed, Microsoft's IE doesnt work with it, typical!
Anyway the link is here for all you geeks, its is great, free too!
http://www.myie2.com/
