  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
they carded it for a business? lol .. thanks for picking it up too.
camgear is somewhere on a plane from japan to sydney.. its going to get here about 3 days late i think for gavin to put it on during timing belt, etc.. so i'm going to have MJ's camgear. When it does actually arrive, he has mine. All worked out :)
Well it worked out for you but not fo me :)
Oh my Chris you really have dropped off the pace somewhat, must mean you got a life, DAMN YOU!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
Hmmmmmmmm having Ben move in will mean I will be able to catch up to him, as I only have a work laptop which no one uses but me atm, as it has certain company info, so it is for my use only, meaning Benny boy will be without net access until I can get another computer organised :) looks like it is going to take a while!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
If you want to call her that :)
I never cared about post counts anyway, they mean absolutely nothing
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
I don't even get a mention! Damn me and my 6 months with no pc!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
