  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Chris, how's things? I've got some minor tech problems today but nothing I can't fix at the expense of not getting all my regualr work done. Farkin power surges. Well at least the net's workin'. :) :)
Gotta love power surges :)
Everytime there is a lightning storm I am guaranteed more income as people come into replace their fried componentry
Everything was going well, until the lights flickered, and the aircon did the minor interruption sound. GRRRRRRR. Meh. I'll fix it tomorrow. it's not like we NEED a mail server anyway.
Its my cousin, we go out together.... But im sure one moe in the party will be fine with her...
:aroused:
Do you and your cousin like spitroast??????? Smoothline. are you smooth....... you know where..... :aroused:
and Ben toilet candy is the pink blocks that you piss on. Now steal some. The whole point is to steal something that has absoluteley no value to you whatsoever that they are going to have to replace once you steal it.
Ben, hope you dont suffere from withdrawal symptoms, as I dont have a puter you can access at home, just a company lappie, and cant let you use that, for reasons which I can explain later, but yeah sorry dude :)
On the flip side, i'll let me catch up to you on the post count! :)
wont be out tonite cyrice....i'll talk to you tomorrow after work...mum will be dropping me off probably saturday arvo
I wont be home tomorrow night though, hmmmmmmm I am passing through your way Saturday arvo sometime, i could pick you up? But I'll have my kids and all their stuff half filling the car so wont have too much room, dunno if our roomate will be there either, so yeah we'll work something out :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
