  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Chris, how's things? I've got some minor tech problems today but nothing I can't fix at the expense of not getting all my regualr work done. Farkin power surges. Well at least the net's workin'. :) :)
Gotta love power surges :)
Everytime there is a lightning storm I am guaranteed more income as people come into replace their fried componentry
Everything was going well, until the lights flickered, and the aircon did the minor interruption sound. GRRRRRRR. Meh. I'll fix it tomorrow. it's not like we NEED a mail server anyway.
Its my cousin, we go out together.... But im sure one moe in the party will be fine with her...
:aroused:
Do you and your cousin like spitroast??????? Smoothline. are you smooth....... you know where..... :aroused:
and Ben toilet candy is the pink blocks that you piss on. Now steal some. The whole point is to steal something that has absoluteley no value to you whatsoever that they are going to have to replace once you steal it.
Ben, hope you dont suffere from withdrawal symptoms, as I dont have a puter you can access at home, just a company lappie, and cant let you use that, for reasons which I can explain later, but yeah sorry dude :)
On the flip side, i'll let me catch up to you on the post count! :)
wont be out tonite cyrice....i'll talk to you tomorrow after work...mum will be dropping me off probably saturday arvo
I wont be home tomorrow night though, hmmmmmmm I am passing through your way Saturday arvo sometime, i could pick you up? But I'll have my kids and all their stuff half filling the car so wont have too much room, dunno if our roomate will be there either, so yeah we'll work something out :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
