  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
New job's going great sorry. I got involved in talking to someone :D
It's busy. HEAPS different to my old two jobs. You have set timelines that HAVE To be completed by the deadlines. It's great.
Only thing that sucks is I actually have to work for my money now. And I've got internet access where I didn't before. So before when I had no work, I had no net. Now when I have net, I have heaps of work.
Plus at the moment its end of month reports that are due in sydney and then in paris by 10th June :)
I had three public holidays and one full week in my last 4 weeks of work after I resigned. I took a sickie because i had the time, but they argued it and took the money off me because i wasn't entitled to it. Pitty they already paid me for it and then took it away.
I'm just glad to be out of there and not putting up with the bullshit anymore.
My new company rocks and they pay me alot higher than the last place. I have to work alot harder though. Even though that involves sitting at a PC, so its not really hard yacka.
Cant wait to get my GTR back. Been in Brisbane for three weeks and no skyline cruises yet.
Motor was getting pulled out today.
CalaisT3RBO: i saw that.. been on there recently scouting for parts for my RB30E turbo conversion actually..
some guy came around earlier and picked up the 5speed i had.. only advertised it on there on saturday and got a heap of enquiries.
Yes, it is my car in there at the moment.
It's not very healthy :) Well not when we heard it about 3 - 4 weeks ago.
Nice car but! Looks hell clean. Just sounds like a rotary :)
nice 2 see u out and about on sat night so many pplz =|
Yeah we hadn't been down there in a while, and I know why, heaps of people, it's just boring.
Plus props to the cops doing rbt's on the way out. More rbt's and less defecting :)
Yeh was there standing around with 61rly and some other mates..... saw some fool in a series 5 rx7 fly past the carpark and then seeing red blues after him... :) :burnout:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
