  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
here is the pic of mine..real grainy unfortunately before i had my new camera:
http://www.skylinesaustralia.com/forums/at...achmentid=11379
You can see how the 910 just like fits the stock bracket.. 040 or 044 must be quite an effort
