  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
they cleaned the house though :rofl: bean was vacuming when i walked in and amanda just finished the dishes :P
yeah I pick the best housemates, everyone cleans up for me, thank you Ben as well for doin the dishes the last couple of nights!
you saying qld is boring chris????
Nah I am saying that you are boring :jk:
If you re-read what I was saying you will come to the conclusion that I was in fact agreeing with her in regards to Sydney being boring.
(although it really depends what you are into, for example you and Cyrus would find heaps to do along Oxford Street :rofl:)
hehe its all good...payback for you gettin up at 5 in the morning to drop me off
oh i might be moving to the nail gun section next week
Yeah bout that, I had a call from Dan today, I'll talk to you bout it when we get home, nothing bad, but yeah, we'll chat when I get home.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
