  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
those parking spots are reserved for the heavy weight dancing mums eating deep fried anything and disrupting the class ;) skylines stritly forbidden.
bombadores and falcodores olny
Yeap and it's always those mums that are shouting and screaming at their children to behave, sometimes I wounder if some are making their kids to come, Kayla knows if she wants to stop going she can, but she likes going, just doesnt have too good an attension span so by the end of it sometimes she just couldnt be bothered, that's when miss shae holds her hands and does everything with her :D Kayla knows what she is doing :D
oh so its Kayla that does that hand holding thing hehehe. nice work, brownie points with the teacher. Shae says its hard to keep their attention for a whole lesson, particularly when the mums are outside shouting at them.
i get reffered to as a 'dancing dad' these days. having never seen any other men there at all i did get some strange looks from the mums in the beginning... will have to get there earily one day and park across two spots so we can get good viewing seats. get the mums to park at supercheap and walk. god knows most of them need it..hehe.
Yeah it's kinda ackward sitting there, which is why when i see another bloke there, its bloky talk time!
I try not to watch Kayla all the time, as she knows i am watching and will play up more if I am for some reason? Also it is funny, no offense but Miss Shae gives in WAY too easily, if Kayla comes out wingeing then I say lets go home, so she goes back inside and Mrs Lennon just says ok come on dance or sit down and then if Kayla continues then she just gets ignored, BUT Kayla now knows if she goes to Miss Shae with a frowny face, out comes then hand ;)
Which is nice, but also means Kayla knows that she can do it too :D My daughter is really quick to figure out who she can wrap around her little finger and those she cant :D
But all that said, it is nice to see a teacher that is not like totally cold hearted, HAVE YOU SEEN Mrs Lennons Mother TEACH?!?! OMG "Do this NOW CLASS!" :D Siek HAIL! Siek HAIL! Siek HAIL! :D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
