gordon home come you havent got your car back yet? should have only taken 1 day to do the work?  When i got my 100k service done i picked it up the next day
erm.. probably.. they needed to redo the radiator.
I'm picking it up in 20-30 mins actually.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
just spoken to squizz
quick cruise just been organised
time: Now
meet: griffith uni mt gravatt
destination: BP servo then thro ipswitch
costs: fuel and dance class
due to the lack of public organised cruises we have taken it upon ourselves to organise this cruise
CB's essential
round trip 160 KMs
:D
my car went on the dyno .. big flat spot at 4000rpm.. mine really suffers from the stock ECU gavin was saying.. only real solution would be a powerFC.
What sort of snoop james? want me to ask about it, or have a look and see what has been done (if possible)
take it down to enzed
and u will need to get them to tap some brass fittings and a hose tail to go on the pump outlet.
8mm fuel injection hose
i didnt use nylon tape on my theads cause fuel just eats it away anyway, the threads they tapped for me used tapered threads so they sealed themselves up anyway
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
