gordon home come you havent got your car back yet? should have only taken 1 day to do the work?  When i got my 100k service done i picked it up the next day
erm.. probably.. they needed to redo the radiator.
I'm picking it up in 20-30 mins actually.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
just spoken to squizz
quick cruise just been organised
time: Now
meet: griffith uni mt gravatt
destination: BP servo then thro ipswitch
costs: fuel and dance class
due to the lack of public organised cruises we have taken it upon ourselves to organise this cruise
CB's essential
round trip 160 KMs
:D
my car went on the dyno .. big flat spot at 4000rpm.. mine really suffers from the stock ECU gavin was saying.. only real solution would be a powerFC.
What sort of snoop james? want me to ask about it, or have a look and see what has been done (if possible)
take it down to enzed
and u will need to get them to tap some brass fittings and a hose tail to go on the pump outlet.
8mm fuel injection hose
i didnt use nylon tape on my theads cause fuel just eats it away anyway, the threads they tapped for me used tapered threads so they sealed themselves up anyway
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
