  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Man if you want my advice, I'd wait until you got the car up and running and then put all those mods on and then do some heavy duty research into both e-manage and pfc, and also take into account that Gav tunes pfc but dunno if he tunes e-manage so you might need to find someone who can tune it for you, unless you want to tune it yourself!
Man your car is going to be a WEAPON!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
