  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yes but _why_ did it not download, I am sure you'll find it is the programs fault, not the computer, and because it is a fault in the program, then it was caused buy the why it was written and lo and behold it was written by a programmer, which is another user, meaning it was a user error :)
I just log in and print out the reports :)
So I can say it's not my fault! :)
Sorry Erin, I did not mean to imply it was you as the user making it not work, just pointing out that computers do what they are told to, and if the program is wrong then it is a user error because a user created the program.
Poor computers get the blame for everything, when they are just doin what they are told to by the program!
Even when the hardware breaks it is a user fault because it was built by a user, so in all cases it is always a user fault, might no be you, but somewhere along the way it is! :)
